LS6 cylinder scoring opinions
I picked up a LS6 long block recently Tried to inspect best I could. All looked good got it home and Cylinder 7 has some scoring. Whats the verdict. I can feel them with fingernail
That piston is TOAST, its the reason the cylinder is scored. Miost likely the top ring is cracked too. If you run it in short order you will have a non functioning number 7 cylinder. Look carefully at the very top edge of the piston ITS MELTED!
