LQ4 NA Stroker Build Block Questions
Hello All - Working on building a 408 NA stroker Lq4 an my question is what block de-burring prep is recommended if any?
I wanted to do the debur before i take the blk to my machine shop for bore an clean up
Any advice is appreciated greatly!
Also there's a **** ton of casting flash in the lifter galley. I grinded that all down smooth and also I smoothed out the oil drain paths in the lifter galley. Just be careful not to slip and hit the bores with whatever sharp tool u use to grind or de burr.
