compression ratio and fitment
Old Apr 4, 2016 | 06:32 PM
sbf's Avatar
sbf
Default compression ratio and fitment
hi guys i want to no if tea stg 2 243 heads mill to 59cc work on a 03 z06 vette with cr to run pump gas and will the valve clearence be ok
Old Apr 4, 2016 | 08:29 PM
Randy WS6's Avatar
How much did you have milled and what thickness is you head gaskets ? The min. piston to valve clearance is .080"int & .100"ext.and you will need shorter pushrods with shaved heads . if every thing is good ,you should be fine with premium gas and maybe need a few degrees of timing pulled, with a hand held programmer
Old Apr 4, 2016 | 08:49 PM
handyandy496's Avatar
I run pump gas(93) and I'm real close to 12 to 1. No knocks yet! That's with a specked cam from Martin@Tick.
Old Apr 4, 2016 | 08:54 PM
Randy WS6's Avatar
Martin designed my cams also, cant go wrong there for sure.
Old Apr 5, 2016 | 11:39 AM
Aston Tibs's Avatar
To make sure you are OK with the compression ratio and pump gas, you need to calculate your dynamic compression ratio.
http://www.wallaceracing.com/dynamic-cr.php
You want to keep youar dynamic ratio under 9.0:1 and preferably around 8.5:1
Old Apr 6, 2016 | 08:49 AM
redtan's Avatar
The answer can vary greatly based on the cam you have...
It will be perfectly fine with a stock cam, but at the same time valves will smash into pistons with a decent cam.
So tell us what you have?
Old Apr 10, 2016 | 08:43 AM
sbf's Avatar
sbf
im selling the heads to a guy with a vette and wanted to make sure it would fit before i did he has stock cam for now but will change later and i think the ssht cam will work fine
