Deck pitting, epoxy/seal it or run it as is.
I noticed some minor oil residue and gasket pieces in the coolant, so I knew I had to tear the heads down. Clearly the head gasket had failed prior to me owning it. Motor runs/ran good and deck is good other then the pitting around this coolant jacket.
Here it is a little cleaned up, you can see the pitting a little better.
The good news is the new MLS gaskets seal off this port entirely versus the pass through on the graphite, and the pitting is outside the fire ring, so it isnt really critical. Garbage graphite gaskets, lol.
It's going back together later tonight, debating on epoxying the pits, or just throwing it together with copper spray as is.
What does tech think?
^ How that area seals with the MLS gasket.
Edit, copper seal won't seal pits that big anyway, it would work for very very shallow grooves or pitting, but we're talking probably less than a thousandths of an inch.
If you have a few extra bucks get the heads decked to help ensure the best possible seal, if you haven't already.
For what it's worth, I always get overly concerned about pitting, happens every time, never had a problem from them though.
