School me on head/intake ports
Old Apr 7, 2016 | 06:58 PM
usnfenix's Avatar
Default School me on head/intake ports
I plan on going more in depth with my 98 ws6 than i have on my previous f bodies, i have an ls6 intake laying around that i havent done yet but in the distant future i will do a FAST and a yet undecided head choice. I dont understand the differences between the catherdral port and the rectangular/square port design. Are there different FAST port designs for the same 102 or 92 intake? I was planning on a set of mild ported 243/799s or spend the money for a pair of tsp heads but i dont know what port style i should be getting for what will be a 228r cammed bolt on car with a stall.
Old Apr 8, 2016 | 08:42 AM
KCS's Avatar
KCS
Moderator
Rectangle ports are the LS3/LS7 style heads. Unless you find an aftermarket small bore head, they won't fit on an LS1 due to the larger valves.
Yes, FAST does have their 102 and 92mm intakes in different port designs. A FAST 102mm intake for an LS3 will not work with 243/799 heads.
There is a lot of info on this site to help you out. The search function will help you find a lot of this valuable info.
Old Apr 8, 2016 | 11:53 AM
01ssreda4's Avatar
Id stay cathedral, if you can afford a TFS set of heads that would be a good bet. Alternatively porting the heads you already have would be good also. AI, WCCH, and TEA have a proven reputation for cnc porting.
Old Apr 8, 2016 | 07:38 PM
usnfenix's Avatar
still has the stock 98 heads. a set of ported 241s would be a cheap upgrade but if im going down that road I might as well set it right the first time and ge the best I can out of it without breaking the bank, which is why the 243s come into mind. I see 243s for sale all the time coming from 5.3 truck engines and some from vettes. I assume all 243s port designs are not the same? The TSP heads have caught my eye but was unsure on exactly which ones I should be looking for when it comes to cc and all. my basic understanding correct me if im wrong is that a smaller cc raises compression ratio and increases power on N/A motors where as larger intake and cc numbers lower it for FI motors. the overall goal for this car is a rebuild of the engine and a moderate N/A H/C/I build no FI with a small chance of getting the bottle in the future.
Old Apr 8, 2016 | 07:57 PM
KCS's Avatar
KCS
Moderator
Smaller chamber volume will raise compression, larger volume will lower it obviously.
Larger port volume will usually make more top end power at the expense of low end power. Smaller ports will usually do the opposite. There are plenty of exceptions as this is a VERY general guideline. You can go too big of a port to where you aren't turning enough RPM to take advantage of the port, or running too small of a cam, manifold, etc. You would probably be just fine with a 220-230cc runner.
Old Apr 8, 2016 | 08:32 PM
DavidBoren's Avatar
Honestly, for a fun bolt-on car with a stock LS1 shortblock, I would recommend the West Coast Cylinder Head (WCCH) stage two 5.3 heads. They have a 213cc intake runner, 1.95" stainless intake valves and 1.575" stainless exhaust valves, and they flow over 280cfm. The heads are actually designed to maximize flow on the 4.8/5.3 smaller 3.78" bore size. Using them on an LS1, with a 3.9" bore, will unshroud the valves and increase flow. The small combustion chambers will increase compression. And they only cost $1100, which is a steal for what you're getting.
Then just make sure you get the proper thickness of head gasket to set up optimal quench and get a good dyno tune.
Old Apr 8, 2016 | 08:40 PM
tigersooner's Avatar
I have been a member a while but I agree with op that info on heads is a little confusing and the search function doesn't lead to a clear answer.
I've done a lot of reading on general engine sites to just understand engine design.
In regards to this topic. I still get confused on the numeric value prior to the heads. What does the 5.3 designate?
Thanks
Old Apr 8, 2016 | 08:47 PM
KCS's Avatar
KCS
Moderator
Thanks
That's the volume of displacement of all eight cylinders, in liters.
Old Apr 9, 2016 | 11:59 AM
01ssreda4's Avatar
Thanks
What motor the heads came on. 5.3 heads have the smallest combustion chambers and are the worst flowing stock head.
Old Apr 9, 2016 | 03:04 PM
That's what I thought. So it never made sense to me that we would take a 5.7 l engine and put heads from a 5.3 l engine on our engine. I understood that this tactic works for some people because it probably increases compression. But i don't think it is a setup that you can grow with.
I'm still trying to learn though.
Old Apr 9, 2016 | 04:54 PM
Darth_V8r's Avatar
Moderator
That's what I thought. So it never made sense to me that we would take a 5.7 l engine and put heads from a 5.3 l engine on our engine. I understood that this tactic works for some people because it probably increases compression. But i don't think it is a setup that you can grow with. I'm still trying to learn though.
there are companies that take the 5.3 heads and port them out to make very good budget heads for the 5.7.
The 706,862 heads flow the same as the 853,241 heads, so you lose nothing and gain compression, even without porting.
Old Apr 9, 2016 | 08:24 PM
DavidBoren's Avatar
The ported truck heads offer plenty of room to grow, unless you are talking about eventually stepping up to, or "growing", into a 383 stroker. Then, just get some Trick Flow Specialties 220 "fast-as-cast" heads from Brian Tooley, and be done.
The TFS 220's are excellent heads for a 5.7, as well.
That being said, I still think the WCCH stage two 5.3 heads would serve you very well, and for the price, they are definitely worth looking into.
