Newbie budget build questions
Side note: i would love to use a t56 but they are a bit too expensive for me right now. Just wondering if the 4L80e transmission will work well with a car as i know its mainly a truck engine... Thanks
Then, once you are familar with the outside of the engines, and how to torque bolts and keep the motor clean, you can move on to building something. The insides of modern engines need to be kept doctor surgery clean if possible. When you do put something together, it should be in a clean room, with filters, and it needs to go together quickly so nothing has a chance to get inside it.
https://ls1tech.com/forums/conversio...de-1500-a.html
http://www.chevyhardcore.com/tech-st...kyard-ls-swap/
As to the rest, and it depends how much you have to work with. I can easily drop $4000 into a pair of rear mount oil-less turbos and another $500 fabricating an elegant mounting solution, and we havn't even started on the chassis or engine or drivetrain and already spent double what others have spent on just the engine. On the other hand, there are $180 shipped turbos available from ebay, and $150 manifold solutions.
