Removing Cam with Double Roller Chain - Do I need to remove Oil Pump?
Well had some more time this afternoon... the timing gear won't come off the cam. I have a Rollmaster Double Roller... I'm afraid I'll have to remove the oil pump to get it off. Why can't anything be easy.
I have the cam bolts out, but it's not budging. It has a little bit of room before it touches the oil pump, but I have a lot less room to play with than a single roller. ugh. But the issue is, it's not moving at all. I don't know if the double roller is too tight or what. But when I put on, it was a pain, but I had it on the crank sprocket and got it on the cam.
I don't know if it'll come out without me removing the oil pump. I really don't want to do that. It was a nightmare getting that on with it on a stand. I can't fathom how terrible it will be still in the car.
I got it off.... issue is the timing chain damper won't let it fall.
So, off comes the pump... and yep, I dropped a spacer down into the pan. Wasn't really expecting to do it, so didn't really prepare. Spent the evening dropping the pan. Hope I can find the very non-magnetic thing. Otherwise, I'll be pulling the motor. And I'm not putting it back in stock. LOL
Moderator
Received 1,853 Likes
I got it off.... issue is the timing chain damper won't let it fall. So, off comes the pump... and yep, I dropped a spacer down into the pan. Wasn't really expecting to do it, so didn't really prepare. Spent the evening dropping the pan. Hope I can find the very non-magnetic thing. Otherwise, I'll be pulling the motor. And I'm not putting it back in stock. LOL
You got a tubular K? Makes dropping the pan much more easier
Moderator
In all seriousness, once I did the K, my first question was - how the hell have I been working on this thing all along? So much room. My next F body build, tubular K will be the first mod.
I can now change motor mounts without pulling the headers. That's how much room you gain.
