My first LS build, advice, guesses? etc
Old Apr 21, 2016 | 03:26 PM
468BBO's Avatar
Default My first LS build, advice, guesses? etc
Hello all,
I have stepped away from carburetors and big blocks to build my first LS.
What I have:
2002 LQ4 Block
224/228 600/600 Texas Speed Cam 114 LS
Trunion kit for the rockers
All ARP bolts
Wiseco 370 cid Forged Piston Set: 4.030
Texas Speed & Performance 6.125" Super H-Beam Connecting Rod Set with ARP 2000 Bolts
GM LS2 & L99 Crankshaft, 3.622" Stroke, 58x
316 heads, minor port work, larger valves (but I do not have the valve size at the moment)
Total compression estimated by Texas speed 10.6:1
Magnuson MP112 with 90MM inlet, 92MM throttle body, 2.8" pulley fully reworked by Magnuson, fuel crossover added
Thorley headers
Do you guys have any advice regarding the build? See any mistakes with part selection?
The purpose for this engine is just a driver, something fun and hopefully reliable.
Any idea what kind of HP/TQ I should expect?
Thanks
Old Apr 21, 2016 | 03:46 PM
Mavn's Avatar
"I MAID THEESE"
is the 58x going to work with the computer youre using?
Old Apr 21, 2016 | 03:54 PM
moekluse's Avatar
Do tons of research and watch tons of videos. They will help alot.
Old Apr 22, 2016 | 07:09 AM
468BBO's Avatar
Default re
I hope so, the engine and computer came from a cube van, Speartech built the harness and depinned the computer.
Old Apr 22, 2016 | 01:44 PM
JoeNova's Avatar
Restricted User
If you're going to use a 58x crank with a 02 computer, you're going to need a Lingenfelter conversion box.
Old May 3, 2016 | 01:32 PM
468BBO's Avatar
Thanks for the help, the crank is a 24X, I had to verify with Texas Speed!
Any idea what kind of power this thing should make?
Old May 3, 2016 | 04:13 PM
nine8ss's Avatar
M6 or A4?
Old May 3, 2016 | 05:46 PM
468BBO's Avatar
Default Re
A4
4l80E
Old May 4, 2016 | 09:49 AM
KCS's Avatar
KCS
Moderator
Compression seems high for a blower application. I would have gone with 9-9.5:1.
Old May 4, 2016 | 01:14 PM
468BBO's Avatar
Default re
Texas Speed had suggested that that would be optimum for a blower that small, I hope its not an issue, they did state if I was running a 1900 or 2300 I would need to drop the compression a bit!
Old May 4, 2016 | 01:25 PM
Crf450r420's Avatar
Looks like fun to me. Enjoy it.
Old May 4, 2016 | 04:36 PM
imma_stocker's Avatar
Which headers are you running? Not familiar with Thorley...
Longer tubes the better, LS motors tend to favor larger primaries than SBC and BBC. 1-7/8 minimum IMO, matches up with exhaust ports and OEM gaskets like taters and gravy.
If you are willing to add a meth kit, it'll help the blower and motor stay out of detonation. Even water injection (straight distilled water) will help reliability and performance.
