Compression test results with only a starter
Old Apr 24, 2016 | 06:35 PM
cmd1126's Avatar
Default Compression test results with only a starter
I'm getting 180 with stock heads larger cam and .010 over Pistons. Is this too high?
Old Apr 24, 2016 | 07:35 PM
bbond105's Avatar
My stock engine was around 220 psi. Did you get your problem worked out with your starter?
Old Apr 24, 2016 | 07:41 PM
zraffz's Avatar
Compression really won't ever be "too high". It ranges tremendously from motor to motor, too.
Don't worry, that will go down a bit during break in.
Old Apr 24, 2016 | 08:36 PM
cmd1126's Avatar
The stock starter isn't turning it for se reason even with a new one so I'm gonna get a 3 hp one and see if that works
Old Apr 25, 2016 | 08:17 AM
VandykeT/A's Avatar
The motor does turn easy by hand doesn't it? I've never had a problem with a stock starter cranking my 408. Hopefully its just a bad starter.
Old Apr 25, 2016 | 09:45 AM
cmd1126's Avatar
It was a complete rebuild so could it be that it's just tight due to new parts and higher compression? I mean the bearings felt tight early in the build but the plastic gauge looked good.
