SLP ZL 402 Stroker a flop, you tell me....
Old 06-24-2004, 04:00 PM
  #41
horsepower's Avatar
Guys -
The block is built under the same criteria GM uses on the OEM build of LS1/LS6. The rotating assembly is properly balanced. The block is not 'secondarily' decked, or decked a second time - no need...it is plucked directly off the OE assembly line.
As for 'blueprinted' - no. Lets reserve blueprinted for something that gets matched bearings, squaring fixtures, etc - true blueprinting is wonderful, but not for the masses...just way too much $$$$ for street / semi-pro usage. For 3595, you won’t find a truly blueprinted engine. I generally think people use the term 'blueprinting' too freely when describing an engine. The SLP engine is a properly engineered and precisely assembled short block -
Availablity - these will be built and on the shelf, ready to sell. They are NOT available yet, but we are working on it! NO CORES - sold outright.
Sales tax, absolutely for NJ buyers – unless you are a ‘reseller’.
Best regards,
Brian
Old 06-24-2004, 05:38 PM
  #42
JS
JS's Avatar
IS.....
The finish bore is done by SLP?
The block is line bored for the long stroke crank?
Old 06-24-2004, 10:25 PM
  #43
ULTIMATEORANGESS's Avatar
just curious.would SLP be installing these blocks at their nj installion facility if asked?
Old 08-03-2004, 05:20 PM
  #44
Billiumss's Avatar
A bump for those having some questions...
Old 08-03-2004, 06:16 PM
  #45
Monza355's Avatar
Default Zl 402
This looks like a good deal. I would just like to know the weight of the iron block vs the aluminum block. If it is only 60-100# I might consider it for my Monza instead of the LS1.
Monza355
Old 08-03-2004, 07:06 PM
  #46
bigdsz's Avatar
If I remember correctly the iron block weighs 108 lbs more.
Old 08-03-2004, 07:18 PM
  #47
Monza355's Avatar
Default Zl 402
108lbs, so that would weigh about the same as my current iron block/ aluminum head 355. I need to get weight off the front end so I'll probably stick with the all aluminum motor.
Monza355
Old 08-03-2004, 07:27 PM
  #48
Black Sunshine/ 00SS's Avatar
It does look like a great deal. However, about the balancing & blueprinting, I've copied this from HPE: "Fully balanced and blueprinted at HPE to our extremely precise tolerences for a long maintenance free life" Their product is similar in parts, however, comed fully blueprinted & balanced. I guess it is for the masses
The SLP advantage is that it is on the shelf and immediately available.
Old 08-03-2004, 09:31 PM
  #49
-=Merlin=-'s Avatar
Sunshine
After the statement made by Horsepower I would call and find out what "blueprinted" really means.
Old 08-03-2004, 11:41 PM
  #50
FASTONE's Avatar
One of the head guys at SLP stated that it was internally balanced.
Old 08-16-2004, 05:40 AM
  #51
gillbot's Avatar
I'm gonna bring this TTT one more time with another question. I didn't see the type of fasteners used. OEM GM or ARP, etc? I thought the GM rod bolts were weak from the get go so it would be nice to know if these are ARP, one less concern with a higher powered engine.
Old 08-16-2004, 08:53 AM
  #52
Mike K.'s Avatar
Did we ever get an answer as to what parts are being used in the motor?
Who makes the crank?
What kind of rods?
What kind of pistons?
Old 08-16-2004, 10:02 AM
  #53
JF WS6's Avatar
What kind of rods?
This was on page 2 of this thread.
"Here are the main ingredients:
1- Production 6.0L cast block
2 - Internally balanced rotating assembly
3 - SLP spec'd Eagle 4" crankshaft
4 - SLP spec'd 6.125" I-beam rods (Eagle and Manley)
5 - SLP spec'd 4" pistons, 2618 forging (Ross and Manley)
N/A version (approx 11.2:1)
Heavy-Duty, Forced Induction version (approx 9:1)"
And as far as using GM rod bolts/main studs etc., I highly doubt they will be using weak factory GM fasteners with an Eagle/Ross/Manley forged rotating assembly.
Old 08-16-2004, 10:34 AM
  #54
STF Veteran
99-LS1-SS's Avatar
This sounds like a very reasonable price for what you get. After my baby gets here and my money gets back in order I am probably going to go with something like this.
Old 08-16-2004, 03:09 PM
  #55
gillbot's Avatar
I doubt they'd use GM fasteners also but until I get confirmation otherwise... I've seen crazier things happen before.
Old 08-16-2004, 04:37 PM
  #56
2xLS1's Avatar
Why isn't this considered sponsor bashing? And what is wrong with stock GM bearings?
Old 08-16-2004, 08:04 PM
  #57
MelloYellow's Avatar
Still need High Compression vs. Low Compression Piston Dish defined.
Heads will have a big influence on Compression Ratio.
What chamber cc are they assuming for their calculations? 66-67cc ?
Old 08-27-2004, 03:15 PM
  #58
wait4me's Avatar
thanks slp for clearing that up. sounds like a pretty good deal, i just bought a lunati 395 stroker kit a month ago for 3500 and still need a block, and ive been waiting for 1 month now and it still hasnt come in..... i wish i found this deal first.. id be done...
Old 08-28-2004, 01:56 AM
  #59
Lostpatrolman's Avatar
I doubt the HPE is fully blueprinted. I agree the term has been adapted to be used very loosely and flexibly. I think they are using the term like horsepower said. The time required to fully blueprint an engine is rediculous.
Old 08-28-2004, 02:19 PM
  #60
SleepieAce's Avatar
Originally Posted by 422 SS
Bill you'd be crazy to buy that from SLP.You know too much local talent between Dayton and Columbus to waste your money.
I didn't see this thread the first time around. It's an interesting read.
I only have two questions: Who are you guys using in the Dayton/Columbus area? I've been looking for someone to install a forged engine w/heads and cam on my Vette. And would this engine work in the Vette?
Quick Reply: SLP ZL 402 Stroker a flop, you tell me....
