Free floating lq4 piston
GM makes two types of connecting rods. One is a press fit wrist pin and one is a floating wrist pin. The floating wrist pin style uses a funky looking c-clip on either side and you can disassemble yourself. The press fit wrist pin, as its name suggest, is pressed in and on occasion can destroy the piston when it's removed.
If you have an LQ9 (flat top 6 liter) and want to use a direct swap GM piston, look for 2005+ LQ4 (dished) pistons.
Edit:
Now I get what you are asking. I'm not familiar if they share wrist pin diameters or not. Any aftermarket dished piston that is designed for a 2005+ 6.0 should be a floating wrist pin as long as they are designed for stock rods.
