Build Advice
I didn't know my clutch packs in the rear needed changed so I had a lot of slippage. 1st time I tried dyno tuning with a huge vacuum leak intake and crappy injectors I put down 450rwhp/440tq. After I fixed them and went back for the tune it put down 430rwhp/420tq with the clutch packs completely useless. So I need to go back to get a true number now that there is no slipping.
My biggest hold back in pwr is my stock 243 heads. They are not ported or milled. Once my car get's a new coat of paint I'll be saving up for heads.
Times at the track...like I said with traction it moves out. Especially when I'm in 3rd and 4th. It just pulls hard. Only negative I can say with 4.11 gears is the gas mpg takes a hit but then again I'm not really looking for mpg....
My 403:
LQ4 Block bored 4.005"
K1 4" Forged Stroke Crank
Polluter stg3 Cam
DSS Forged Pistons
SCAT I beam 6.125" Forged Rods
King bearings
ARP studs
243 Heads with BTR Dual Plat. 6x springs,
LS7 Lifters
LS2 timing chain
Melling 10296 Oil Pump
