Looking to do a ls1 cam only
Old Jun 4, 2016 | 09:45 AM
unioncarpenter84's Avatar
Default Looking to do a ls1 cam only
I recently just bought a 2001 ls1 with 25k miles.
It has a vegance racing vxr5 236-238 cam with ls2 timing chain and meiling high volume pump the 10296.
Its sitting on the engine stand looking around to see what is the best cam to put in it and which stock head. I can get 241 heads very cheap to throw on it.
Or i have a option of getting afr 215 65cc heads
Its a 98 trans am full weight. 4:11 gears. longtubes. slp lid.and t56 car on a qtp 27 inch tire
looking to get 130-135 on a little bit of spray
i have a nx plate kit
was thinking about doing a dry kit with the halo set up in the air box
looking for thoughts and advice thanks
Old Jun 4, 2016 | 02:46 PM
HCI2000SS's Avatar
Why do you wanna change the cam?
Old Jun 5, 2016 | 07:51 AM
Im just throwing it out to there too see if there is another cam out there to make more power with spray.
Old Jun 5, 2016 | 09:18 AM
HCI2000SS's Avatar
Sure there other cams that may make another 10 hp or so, but if it were me I'd save my money and keep what I've got, and spend that money elsewhere on the car. What are the rest of the specs on the cam?
Old Jun 5, 2016 | 01:27 PM
http://vengeanceracing.net/vengeance...8-602-605.html
Old Jun 5, 2016 | 02:30 PM
HCI2000SS's Avatar
Nothing wrong with that cam at all. In fact the specs look pretty decent to me. That's just my opinion
Old Jun 5, 2016 | 02:43 PM
Yeah thats what im thinking its probably going to stay.
It has a meiling high volume pump the 10296 one and ls2 timing chain.
May just leave all that and run with it. Alot of people dont like the pump but some do its hit and miss on opinions on things
Old Jun 5, 2016 | 02:45 PM
It has 215 afr heads on it now but stock lifters is it safe to keep the stock lifters in the motor with that set up
Old Jun 5, 2016 | 09:17 PM
thompson's Avatar
Many people choose to run the factory lifters in setups like yours. My only concern would be if they are the original factory lifters, or if they were replaced with a factory style set when the heads and cam setup was installed. Regardless there are a lot of people running similar combinations with a stock style lifter and no problems. Feel free to give us or send me a message directly. We are happy to help.
Thank you,
Aaron@ThompsonMotorsports.net
Old Jun 6, 2016 | 08:08 AM
They are the stock 25k mile oem lifers that cam in the motor he didnt replace them when he did the heads
Old Jun 6, 2016 | 12:31 PM
Rise of the Phoenix's Avatar
Is it a daily driver? If you have the chance to run the AFR 215cc heads, I'd do it. Heads are where it's at on a NA combo. That VRX5 cam should work well with those heads too.
Old Jun 7, 2016 | 12:37 PM
No its not a daily just something to go up the track and have fun with.
Old Jun 7, 2016 | 01:05 PM
SCott5's Avatar
Car only made 420/430hp (can't remember which he told me)heads and cam with fast 102 and trapped a best of 114 I think if I remembered it right. With the same drivetrain that's in union carpenters car now.
