so..motor idea...
Old May 29, 2016 | 09:36 PM
dans2000camaross's Avatar
Default so..motor idea...
ok so ive been planning some more work on my camaro for this coming up winter. I have a mitsubishi 16G (TD05) turbo that ive rebuilt. I would love to install a much bigger compressor on it(20G) and build a aps style kit. using my stock manifolds and cutting the flanges or fabbing my own headers. my main focus is the engine, i have searched for a while now and wanna run some ideas by you guys, i would like to keep her a 346...
ARP rod bolts
LS9 cam
LS6 pcv with oil catch can
RHS pro elite LS7 heads
stock LS7 intake
bar link lifters
hardened pushrods
double roller timing chain
shaft mount rockers
i would like to do that first so i know the engine is setup for boost...
then i wanna use said setup with those turbos and duplicate the APS/incon TT kits. my questions how will that engine setup perform n/a?
Old May 29, 2016 | 09:38 PM
JoeNova's Avatar
Restricted User
You can literally skip every single thing you mentioned for a pair of 16G turbos.
If a customer came to me saying that he wanted half of that stuff for his build, I might consider smacking him LOL.
Old May 29, 2016 | 10:09 PM
slogo's Avatar
Will the RHS pro elite LS7 heads fit a LS1, are they for a small bore?
Old May 29, 2016 | 10:15 PM
JoeNova's Avatar
Restricted User
The real question is, is it really worth going super overkill on the heads, spending $3000 to gain 25-30 HP, when you can do the exact same thing with 2 extra PSI on a twin turbo setup?
Increasing boost doesn't cost any extra money, you know.
Old May 30, 2016 | 08:10 AM
What would those heads be good for then?
Old May 30, 2016 | 12:28 PM
JoeNova's Avatar
Restricted User
For a 427+ CI N/A race car.
Old May 30, 2016 | 01:11 PM
Millenium Z06's Avatar
Nope, he'd need small bore heads
Old May 31, 2016 | 08:41 AM
that's what I'm talking about....rhs has a head with ls7 ports but they are for small bore.
Old May 31, 2016 | 08:43 AM
JoeNova's Avatar
Restricted User
Still 100% pointless on a small cube turbo build.
Old May 31, 2016 | 03:58 PM
how so? wouldnt the flow be beneficial? im kind of a noob at all this so bare with me
Old May 31, 2016 | 05:04 PM
JoeNova's Avatar
Restricted User
Yes, they will flow more. Yes, you will gain a little bit of power for the $3000 spent on heads.
You can gain just as much power by turning up the boost, for free.
Why do I make 300 HP more than the old LS9 ZR1 on a little 5.3 with stock cathedral port heads? More boost. Could I have done it with aftermarket heads? Yes, and I would probably be making the exact same amount of power.
Old May 31, 2016 | 07:16 PM
Ok my next question is why would one need a head like these? Wouldn't they be good on a 408 or larger
Old May 31, 2016 | 08:36 PM
JoeNova's Avatar
Restricted User
When you need the CFM flow, you buy those heads. Like when you're trying to make 700+ N/A and you need a head that isn't a flow restriction.
Turbos don't work that way. You don't increase CFM with a turbo, you flow the same CFM but at a higher pressure, so your stock heads are just fine for a turbo build.
