Cam for 01 4.8 ls1
http://store.cammotion.com/48l-290-ci-95-compression-2
If you're planning to do long tube headers, and other assorted bolt ons, and you want to sound like a cammed small block, this is worth a look:
http://store.cammotion.com/little-ch...otrod-camshaft
I run a Cam Motion stage 2 drop in cam (205/210 duration) in my 5.3, it made 41rwhp and 22 ft/lbs over stock and I kept the stock gears, stock torque converter, stock exhaust manifolds, and stock pushrods. Drives like stock just makes more power everywhere.
Also, a bully dog programmer isn't typically going to be versatile enough to tune a choppy cam. It can take many writes and rewrites to get a choppy cam to settle down for you. And the smaller the motor, the trickier it can be.
We have a few truck cams that will work perfectly with stock drivetrain, have great lope, and make some serious power even in a 4.8l plus ls7 lifters and the gasket kits to help you rebuild the top end. We are pretty much a one stop shop!
Let us know if we can be of any assistance!
Mid 220s duration is where you start to reach the point of diminishing returns on the trucks. LSA, advance, and lift will be the biggest factors after that. We have quite a few truck cams that work very well in the 4.8/5.3/6.0 and they all range from 210ish duration to low 220s duration on the intake. They still make loads of torque down low and in the mid range.
What kind of issues did you have with LS6 springs?
The LS6 cam likes RPM even in a 5.7 and was designed around a ~3,300 lb car with a manual transmission. I've never seen good results from one in a N/A truck application.
Sure a bigger cam can gain more, but you get into the point of needing other parts: stall, gears, longtubes, better springs, and pushrods.
I'm pretty happy with these gains and this powerband, the best thing being the truck has more power from idle up and perfect manners:
The numbers are somewhat deceiving as this dyno is stingy as hell (25-30 hp low on a typical cammed/bolt on ls1) but the gains definitely show. I literally just changed the cam and valvesprings (ls6 springs) and retuned. The truck was tuned before the cam as well so gains from the tune were minimal.
It's not setting the world on fire but it's doing a lot better than stock without any negatives or needing any other changes.
