Best combo head and cam?
Old Jun 13, 2016 | 05:16 PM
Nighthawk_WS6's Avatar
Default Best combo head and cam?
I was wondering what a good head and cam would be for making 450 rwhp. Would the stock bottom end and stock 4l60e other than a 3500-4000 torque converter hold up? This is a daily driver and I would like some track days, also quite a bit of spirited driving on the streets.
Old Jun 13, 2016 | 05:19 PM
speedtigger's Avatar
Old School Heavy
Moved to internal engine section for you.
While I am here, this is an interesting video for you of my old 6 liter. It is in your desired range.
Old Jun 13, 2016 | 05:36 PM
HCI2000SS's Avatar
Have a budget in mind?
Old Jun 13, 2016 | 05:44 PM
Dragls's Avatar
The best?
Let mamo or tooley spec out the whole setup.
Old Jun 13, 2016 | 06:00 PM
$3000 give or take.
Old Jun 13, 2016 | 06:02 PM
How would I contact Mamo or Tooley?
Old Jun 13, 2016 | 06:06 PM
HCI2000SS's Avatar
For 3k you get a good set of ported 243 heads with cam and an accessories. As long as you have good exhaust 450 rwhp is very doable. What intake do you plan to run?
Old Jun 13, 2016 | 06:10 PM
If I get good enough heads and cam I would like the 102 FAST and 102 Fast Toys air lid. Have an SLP Loudmouth II exhaust right now.
Old Jun 14, 2016 | 08:56 AM
manzo81maro's Avatar
$3000 give or take.
Tony Mamo - look up Mamo Motorsports, probably best to send him an email...
Expect to dig deeper into your pockets, but you're gonna get top notch quality and optimal HP
Old Jun 14, 2016 | 10:01 AM
Rise of the Phoenix's Avatar
Trick Flow 220cc as cast heads hand worked by Brian Tooley
Brian Tooley or Martin Smallwood custom spec'd cam
Port matched FAST 102mm intake/TB
1 7/8" headers
3" true dual exhaust setup
BTR .660 spring kit
Old Jun 15, 2016 | 04:57 AM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
My new heads (which are extremely affordable) would punch that number with the right set-up and complimenting mods. The package is the key.....everything must compliment and work well together to make it all happen....valve control is especially important and unfortunately an often overlooked item in alot of builds I see....it can hamper performance potential a great deal because it rears its ugly head as the engine is approaching peak power and beyond. Better combinations carry power well past peak....those always run the hardest due to the serious gains in average power that brings to the table
PM or email me for more info.....or pick up the phone
Here is a thread on my new MMS 223 heads.....worth a read if you have a few minutes
https://ls1tech.com/forums/generatio...man-heads.html
Regards,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Jun 15, 2016 | 08:39 AM
JoeNova's Avatar
Restricted User
$3000 give or take.
That's more than enough for a nitrous setup, and just about enough for a cheap turbo setup.
