radical 5.3 cam?
Old Jun 16, 2016 | 11:56 PM
onehunglow's Avatar
Default radical 5.3 cam?
looking for options on cam selections on my 5.3 turbo build. wanting something in the 2000-6500rpm, maybe 7000 on the high side of limit. i want that big block shake the fender off idle, it' be in a s10 maybe 3000lbs max. street driven.
open to any suggestions, or "this is the one i have"
.030 over to clean it up.
balanced.
90mm holley high ram.
72mm turbo.
3500stall.
4:10 rear gears. w pac springs, or equal
706 head/ compression 9:5'ish,[basicly stock]
Old Jun 17, 2016 | 12:12 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
The cam will depend on your lifters. above 6500 with a turbo also will need no only high quality lifters but a high volume oil pump.
Anyway on to the cam. i would recommend something in the 233/242 area on a 114...might be pretty tight if youve milled the heads youd want to double check unless you have forged pistons with valve reliefs. Does have some overlap. there are alot of cams in that range on youtube...search to your hearts content. We either have a cam in the area or can spec you one close! The end result is also all in the tuning/timing and the exhaust.
Cam kits run 689 with dual springs
Old Jun 17, 2016 | 12:20 AM
onehunglow's Avatar
i was thinking ls 7 lifters?
it will have a hi volume pump.
heads not milled, but am going up on valve size. the pistons are dished hyperthuetics. step up from stock.
Old Jun 17, 2016 | 12:34 AM
I would recommend a step up to the morel 5315 honestly. not alot more money but higher quality internals and still drop in. Then a melling 10296 oil pump (high volume). The cam we recommended will sound pretty amazing. There are alot of sound clips of similar cams (like the ms3) oit there...keep in mind that the ls1s larger displacement will tame the cam and the sound somewhat also. I would stay away from the ms3 cam and similar as the lobes cam be quite aggressive...if TSPs new cams do in fact use the same lobe ramp rates. The xer style lobes can be hard on springs.
Old Jun 17, 2016 | 06:41 AM
JoeNova's Avatar
Restricted User
Big thumping cams and a turbo = poor results.
If you want that big block sound, ditch the turbo and go N/A.
Old Jun 17, 2016 | 08:06 AM
farmington's Avatar
what he said
Old Jun 17, 2016 | 08:12 AM
KCS's Avatar
KCS
Moderator
Or just go with a big block lol
Old Jun 17, 2016 | 08:15 AM
Voluptuous-V's Avatar
I have a brand new 241/244 .621 custom grind comp cam for sale!!!!
Old Jun 17, 2016 | 12:10 PM
gsxrred1000's Avatar
I like this cam. Ljms stage 3 turbo. Sounds good at idle and makes good power
Old Jun 17, 2016 | 11:25 PM
onehunglow's Avatar
yeah, its sounding so....
Old Jun 17, 2016 | 11:30 PM
You can dial in quite a bit of exhaust duration and have a solid LSA and still make it sound good and have the turbo power. But if you want it slobbering all over the place, NA is nearly the only way to do it.
Old Jun 17, 2016 | 11:51 PM
onehunglow's Avatar
Originally Posted by gsxrred1000
I like this cam. Ljms stage 3 turbo. Sounds good at idle and makes good power Lil john / BTR stage 3 turbo cam 5.3l Ls first startup - YouTube
$400 for a cam? not knocking it one bit, but im torn on spending that kind of $ on a first build just with a cam. love the video its what im looking for. honestly im stepping into something un-know for me on these, and its a "in your face" learning experience. way diffrent then a $350 complete cam kit for a gen 1
Old Jun 17, 2016 | 11:55 PM
Nearly all LS cams range from 375-425 to 500 depending on who's name you wish to buy.
Old Jun 18, 2016 | 08:38 AM
Yup all ls cams are 375+ roughly 900 if you do hv oil pump ,gaskets ,springs,retainers,pushrods etc. But the ease of installation is great.
