Engine sitting for 2 years.
Old Jun 22, 2016 | 08:09 AM
DREAMZ28's Avatar
Default Engine sitting for 2 years.
My Trans Am has been down for a while with a spun rod bearing, and about 2 years ago I found an LS1 to drop in it. I've had the intake ports sealed off with a few layers of thick trashbags, but the exhaust ports have been exposed. There isn't any oil in the motor. It's been in a garage. No water or any other fluids have been near it.
I'm gearing up to drop the new motor in, but I'm starting to be concerned about its state.
Old Jun 22, 2016 | 08:43 AM
redtan's Avatar
Check the exhaust valves for rust, if it's excessive then you would want to clean that up.
And what do you mean by there's no oil? Was it drained through the pan or was it assembled without out?
