Cam'd 5.3L questions
Old Jun 27, 2016 | 12:52 AM
Mark Griffitts's Avatar
Default Cam'd 5.3L questions
Hey guys,
Was wondering on what cam I should be getting I was looking into the proc am 212/218 I will be also changing out the stock 4l60 and going to a 4l80 do I need to mess with stall or am I ok with stock 4l80
Thx
Griffy
Old Jun 27, 2016 | 01:24 AM
Darth_V8r's Avatar
Moderator
Originally Posted by Mark Griffitts
Hey guys, Was wondering on what cam I should be getting I was looking into the proc am 212/218 I will be also changing out the stock 4l60 and going to a 4l80 do I need to mess with stall or am I ok with stock 4l80 Thx Griffy
if your primary goal is acceleration, get the converter. If it's towing don't.
Old Jun 27, 2016 | 07:17 AM
Thx Darth. I am looking for acceleration. Any recommendations for a converter. This truck will never tow anything but it's self.
Old Jun 27, 2016 | 07:20 AM
MaroonMonsterLS1's Avatar
Lots and Lots of variables here. Give us some more info on the setup and the goals. What 5.3 (LM7?), compression, other mods, what's it going into, what's the car going to weigh, what are your goals for the thing? Do you want to tow, nice street cam, street strip, granny car, etc. etc.
Old Jun 27, 2016 | 07:24 AM
The build is a lm7 swap into a 1956 international s100 series pick up. Right now engine is stock looking to do cam, headers, intake, and maybe heads.
Goals is street ride that is taken to shows. Maybe the odd burn out. Don't want it to kick like a mule when shifting because the wife will drive it from time to time(only way I could sell the project to her)
Old Jun 27, 2016 | 07:49 AM
That 212/218 isn't a bad choice. I would go a little bigger, especially if you plan on doing heads. You can keep it on an early ICL with a narrow LSA to keep the torque down low. Something like a 26-2800 stall might be right up your alley. Some guys will recommend bigger (say a 3600) but that's for all out acceleration. It works in an f body, might not work so great in an s100 that your wife wants to drive.
For better converter recommendations, I'd head over to the automatic transmission section and pick their brains. https://ls1tech.com/forums/automatic-transmission-13/
Old Jun 28, 2016 | 02:06 AM
Darth_V8r's Avatar
Moderator
I was going to suggest 3,000 for your purposes. Maroon's recommendation for 2600-2800 might be better. I don't drive anything without a man pedal
Old Jun 28, 2016 | 07:16 AM
The man pedal is always the one furthest on the right^^
