Pushrod lenght and preload
Some say .020 preload , some say .050, some say between .080 and .0100.
Which is it ????????
I have a 2004 lq4 stock bottom end and pistons. 799 heads milled .006 for a clean up. Fel pro stock thickness head gaskets, PRC dual springs and titanium retainers, Texas speed Tourque V4 cam.and new ls7 lifters.
With the comp cams pushrod lenght checker (6.8) i get 10 1/4 turns. I checked a few intake and exhaust and I get the same measurements.
So 10.25 x .050 + 6.8 = 7.3125
Now I need to add preload to the 7.3125. The cam package came with 7.4 pushrods. So 7.4 - 7.3125 gives me .0875 preload.
Is this ok ?????
Thanks.
A couple things, though. I'd be looking for something better than LS7 lifters with a big cam and high pressure springs. And do yourself a huge favor, get a set of 8" calipers to measure the length of your pushrods more precisely. The turn method isn't as accurate and your 7.4" pushrods will vary - they're not exactly that length. Heck, you could even go to the local auto store and borrow theirs I bet.
Also the checker seems to be pretty accurate. If I stand the checker and the 7.4 pushrod side by side and use my 6" calipers like a depth gauge the difference between the two is .087 with 10 1/4 turns out.
I will definatley buy some bigger calipers to confirm.
So I should be ok with .087 preload then ?
I would think so based on what I've read. Search Google rather than just this site. Call TSP and confirm since they sell and recommend them. It would make me feel better personally, and if I was in your position. They answer all my questions on the phone, or email me if they need to talk to the engine builder first. Good luck!
Thanks everyone for the help.
What kind of power would you guys think this combo would make ??
Lq4 bottom end freshened up ( new rings rod bearings crank bearings cam bearings, cylinders honed)
New timing chain and oil pump.
Torquer v4 cam (231/234 629/615 111 lsa)
799 heads (valve job, milled .006)
Prc dual valve springs
Stock head gaskets
Edelbrock performer rpm carb intake
Holly 750 carb
Msd 6ls
Full lenght headers, 3 inch exhaust.
I'm hoping to at least see around 400 hp
Kind of glad I did, as now I have a problem.
The pushrod checker comes out accurate at 7.325. However the 7.4 Texas speed pushrods are not exactly 7.4. I measured a few and they are all around 7.417
So now 7.417 - 7.325 gives me .092 preload now. Seems a bit high.
Guess I will exchange the pushrods.
So you could actually be fine is what I'm getting at. Plus, ordering new ones will still give you varying lengths and you can't even order an exact length of some odd number. I think they offer lengths in increments of .025 or .050.
Best case, you'd be ordering 7.375 would probably give you somewhere in the 7.390 range (.065 preload based on your numbers). Worse case, you'd have to order 7.350 (7.365 range, yielding .040 preload).
Those are all just round numbers for the sake of easy math. If you get new ones, measure them to confirm and the preload may change at that point. You have a wide margin for error with your preload.
Side note: I mistakenly read your first post as using the MS4 cam instead of the Torquer 4, which is the only reason I brought up an upgrade over ls7 lifters. I don't think it's as crucial now that I know this, but personally went with Morel 5315s on my Torquer 3 cam FWIW (but mine uses the older very aggressive lobes).
Glad you checked. Yeah the pushrods actually measure put a bit long every time. That said, 092 preload is on the long side but would be ok
I measured a bunch of the Texas speed 7.4 pushrods with calipers. I got 7.422 with most of them. (Some were +- a few thousands)
And I measured the pushrod lenght checker at 10 1/4 turns out with the caliper which gave me 7.325
So now the 7.422 - 7.325 gives me a preload of .097
I think that's a little high.
So best bet would be to get the 7.375 pushrods. BUT this poses another problem. If the 7.4's were actually .022 longer, how much longer are the 7.375's going to be ??????? Maybe 7.390 ?????
I messaged Texas speed as I would like them to actually measure the 7.375's before ordering them.
If you want to re-measure a few cylinders to confirm, I would not even count checker turns. Just adjust it where it needs to be and measure end to end. I never once counted turns, because the stupid thing would turn so easily I couldn't be sure it was accurate (well, and because Darth told me not to). Others have put teflon tape on the threads to keep it from spinning so easily, but still - don't count turns, just measure.
Good luck man!
