What's best Cam only: FM13, TSP 231/237, or G5X3?
Old 06-18-2004, 12:56 PM
Sweet Cheeks
Damage Inc.'s Avatar
Default What's best Cam only: FM13, TSP 231/237, or G5X3?
I have an A4 and want to shoot for 10s cam only. I've been researching these 3 cams and they look like the best right now. As for the car, it's a full bolt on car on a stock LS1 intake and no tune. It's going 11.8s on chrome Zr1s and I plan on doing the following with the cam:
Bogart D10s w/ ET Streets
LSX 90mm manifold and TB
Tuning
Do you think 10s are possible?
Which cam will do it best without heads, or do I need heads?
Thanks.
Old 06-18-2004, 01:01 PM
killer01ws6's Avatar
For 10's
You need heads, and a poweradder,
or some serious weight reduction.
Old 06-18-2004, 01:38 PM
Sweet Cheeks
Sure about that? Heads maybe, but no poweradders. There are a few guys running 10s cam only. Yee of little faith. What do you guys think. Raceweight is 3255 on heavy ZR1s.
Old 06-18-2004, 02:14 PM
Cmarsh93z's Avatar
We can custom grind you a cam that will meet your goals and more! PM me for more info on specs.
Chris
AMS Racing
Old 06-18-2004, 02:27 PM
30th t/a's Avatar
if your running 11.8 just with boltons, id say the G5X3 and the other mods you want will get you low 11s.
if you want 10's with cam only read up on the Trex.
Old 06-18-2004, 02:44 PM
Sweet Cheeks
Hmm. I know I can crack an 11.5x on boltons before I cam it, but which cam do you think will pull the car best?
AMS, we'll be talking.
Old 06-18-2004, 02:46 PM
1fastWS6's Avatar
3255# is pretty light. I'd think if you can get 430-440 hp at the wheels, you should be in the 10's pretty easy with a good 60' time. I think I've see a few cars with the G5X3 that were pretty close to that w/o heads.
30th t/a's Avatar
outta the 3 you listed the g5x3.
Old 06-18-2004, 03:12 PM
distortion_69's Avatar
Default Cam Only
Don't get the FM13.. Get the same cam as me.
236/239 .601/.610 111lsa
I guess you could call it an FM15? It made 419rwhp through my 12 bolt. With a big stall on a stock rear I'd suspect it'd make well over 400 to the rear.
I have no doubts it'd run 10's on a 3200-3300lb raceweight. I'll know what it runs on a 3500lb raceweight next weekend
I have no doubts it'd make similar power to G5X-3 and T-Rex cam in the same environment. Plus it has incredibly good drivability. I have a video I made of me cruising at 1400-1500rpm with no surge.. and it pulling smoothly.
When/if you call, ask Candy about the Ron Jeremy cam hehe. Its a little joke we got going on.
Peace,
Josh
Old 06-18-2004, 03:17 PM
Sweet Cheeks
Is the F13 not a good cam? I've read great things. The only thing is that I want to do it cam only with the option of doing heads in the future if it doesn't work out. The G5x3 is great cam only, but requires custom head work with ported heads I believe. What do you think?
Old 06-18-2004, 03:19 PM
Sweet Cheeks
Peace,
Josh
That sounds like a bad mama jama! How's the idle. Me being an A4 I'd lean toward a 113 or 114 LSA.
Old 06-18-2004, 04:09 PM
PREDATOR-Z's Avatar
On a 110-111 lsa and A4, it is the tune that is going to make the difference.
Big stall of course and a shitload of suspension mods to hook it all up. I also think more weight loss is necessary without heads.JMO
Old 06-18-2004, 04:29 PM
FM13 is a sweet cam. But the Futral Cam I got is a little bit bigger, and more optimized for stock heads. In other words.. you'd be hardpressed to run aftermarket heads on it without getting the pistons flycut. Although there is a good bit of room left according to the Futral guys for safety.. I'd get Allan(sp?) to do the tuning. He worked hard on mine, and its damn near stock drivability. I would think the tune would make or break an a4's drivability. Believe it or not, my cam peaks soon enough that I can shift at 6800 without giving up anything. Alot of guys are spinning their combos up to 7k these days running the 114's and what not. I don't think you'll have any problems with the 111lsa. I'd give them a call though to doublecheck what he suggests. They'll be back in town from North Vs. South on Monday.
Peace,
Josh
Old 06-18-2004, 04:39 PM
TexMax's Avatar
Theres always the option of adding a 100 shot on there after the cam -- pretty sure that would put you in the 10's, but then again, I don't yet have a cam or n20, so I could be wrong...
Old 06-18-2004, 05:25 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
The G5X3 and the larger FMS cams always seem to outdyno the 231/237, but track times are a different animal.
And don't forget TRex.
TSP also has their magistick too.
But! Bigger doesn't always mean faster.
Old 06-18-2004, 06:18 PM
JZ'sTA's Avatar
When I say there is a big difference between 11.50 all motor and 10.90 all motor I mean there is a BIG DIFFERENCE.
I would say you will need a 4200 stall and cut 1.50 60 ft's to even get close.
W/O shaving weight I am gonna say there is very little chance of a 10 sec pass all motor being cam only.
If your race weight is only 3255 you are only helping yourself in your goal.
The is a ton of weight savings. Are you sure this is accurate?
Either you have a lot of time in taking weight out or you only weigh 50 lbs yourself.
Damn that means your car weight less then 3100 lbs that is great.
I also believe you will need to dich the ZR1's and get a full slick b/c you simply will not hook if your making good torque and running a 4000+ stall.
I thing your goal is achieveable but here is my suggestion.
First get a 4000+ stall from Yank or TCI.
Then get one of the cams you are interested in. (G5X3 fan myself)
Then get some slicks and skinny's.
Most importantly get a great tune and launch you ride hard after a fat burnout.
Good luck and keep us posted.
Old 06-18-2004, 08:28 PM
Bill00Formula's Avatar
Hey SoFL02SS,
Have you run at Moroso yet? How did you run?
Just wondering cause I have the G5X3. Trying to work out some wheel hop issues as well as having no rollbar prevents me from going all out.
Bill
'00 Formula
Old 06-18-2004, 09:13 PM
Louis's Avatar
The Fastest Cam only, stock headed car is in Chicago and runs the G5x-2 cam
As far as the X3 needing head work, it doesnt. It will work excellent on stock heads.
Old 06-18-2004, 10:14 PM
!LS1 11 Second Club
Originally Posted by Bill00Formula
Hey SoFL02SS,
Bill
'00 Formula
Haven't run w/ the new setup yet.
Going to Bradenton next weekend to try her out.
Old 06-18-2004, 10:32 PM
offaxis's Avatar
I guess you could call it an FM15? .
Peace,
Josh
Damn
That cam sounds like something I might be interested in . Ill have to make some calls.
Quick Reply: What's best Cam only: FM13, TSP 231/237, or G5X3?
