Previous owner of car says MS3 cam
But these are the numbers on the cam.
3728r/3731r HR113 +4
Previous owner says he didnt check PVC because TSP told him it didnt need to be checked. I am sure the spring install height wasnt checked either....didnt bother asking that.
Most I revved this car to was 6800 on factory tach about 5 times.
Can see where the exhaust valves have been hitting the pistons. 10 of 16 roller lifters are chewed up.
Your thoughts?
Your thoughts?
Remove cam and inspect it, check cam bearings.
Maybe open the oil filter and look for bearing debris..
Start there, if the cam is mangled up you might want to think about engine disassembly.
Not surprised, see guys looking for the biggest baddest sounding cam they can get their hands on not realizing how to correctly set up or what the consequences are for car performance.
Like stated in prior post, I would go smaller and replace parts setting things up correctly.
I bought the car already put together. This happened 300 miles down the road. Yes all will be checked and I will have a machine shop do a little flycutting on the pistons.
Post was just to have a discussion about the situation I am having to discuss with like minded and like interested people.
I have built a few motors all fords. I am new to ls engines though.
I noticed on the plastic lifter retainer cup deals that the lifters were very loose in a few of the slots but some of the lifters were still tight fitting in them if I keep the car which I haven't decided yet I may go with the link bar setup. The short time while it ran I did like the performance of the car so I wouldn't want a smaller cam.
I am not sure it was a MS3 cam either those lobe numbers dont equate to what what the MS3 specs are.
The guy I bought this car/motor from says he feels sorry for me but doesnt think it was a bad build. That I must have floated the lifters so badly I ruined the valve train. However he was still kind enough to donate 500 bucks to rebuild it stand up guy overall but maybe not the most tedious engine builder.
It is in a 65k mile 2000 ss m6 mgw short throw (love the way it shifts)
lq4 6.0 block with .020 over flat tops
ls6 intake 46# injectors 799 heads titanium retainers double springs not
sure of the specs on the springs (which I kind of need so that i can check setup)
trunion upgrade/ .080 one piece comp pushrods
tsp stainless 1 7/8 headers with stainless true dual setup.
4.10 gears stock rearend. tubular k-member aftermarket torque arm and transmission cross member.
Ouch, that lifter looks terrible. What other parts were on the car, springs, retainers...? I dont think i would ever have rev'd my stockish LS1 to 6800rpms regardless of the cam if I did not know what else was in the car.
The previous owner does sound like a legit dude, however his mechanic skills could be a bit lacking.
