Stock block or lsx block
4" stroke on a stock block is a bad idea with that much boost.
Have you ever done anything like this before or are you just throwing out random numbers? What is your power/ET goal?
Unless your car weighs 3600 lbs, you're not going to need 30 PSI to run a 5.0. There are a few guys running 5.20s-5.30s on a stock bottom end 5.3/6.0 at 26-30 PSI. You should be able to run in the 4.90 range with ease with 400+ cubes and that much boost in a 3200 lb car.
Guys like Urban and Bryson have made 1400+ on 4 bolt heads. Bryson did it on a stock 5.3. There are a few other approaching that area now too. I think Jarrett is still running 4 bolt heads and he made 1200whp last year. I think he has upgraded his turbo since then. I just seen his stock 6.0 block spin its way down the quarter to a 173 mph trap on poor prep (1.6x 60 ft).
There aren't too many guys here actually running a filled iron block, mostly aluminum. I don't remember Urban running one. There were a couple of filled aluminum LS2 blocks running ~1800 HP. I'm not sure whatever happened to them. I haven't seen either of them on these forums in a while.
Just because people have done 20+ on factory iron blocks
Does not mean it should be done.
Just my .02
