how to install valve seals?
Old Jun 18, 2004 | 04:58 PM
mattz06's Avatar
Default how to install valve seals?
installing new patriot springs and valve seals. just pry the old ones up? slide the new ones down? tap themdown? how do you know they are fully seated?
thanks!
Old Jun 18, 2004 | 11:22 PM
busavette's Avatar
just put mine on ,just tap em on & they wont go much further theyll bottom out,when you do the next few theyll all show the same amount on the guides.
Old Jun 19, 2004 | 11:59 PM
Inspector12's Avatar
TT-TECH Veteran
I use a socket that is just a little bigger than the seals with an extention and usually able to push on by had but when I get to the back ones I might use a little tap with a hammer ETC... Just look and see if they all look fairly equal.
Old Jun 20, 2004 | 02:19 AM
35th SS's Avatar
just did mine today vlv. seals and swap to dual springs on the car.what a pain in the *** to do on #8 springs.getting ready for the trex cam.
Old Jun 20, 2004 | 07:28 PM
mattz06's Avatar
thanks guys!
