Ls1 with 170,000 miles
Easiest way with so many miles probably turbo set up. 8 lbs of
Boost, beefed up trans with mild converter & 3.42-3.73 gears.
Well set up turbo easiest on bottom end and less RPM needed
Provided engine is in good shape.
NA you would need a lot of Expensive parts and 6500+RPM
very risky with so many miles IMO.
