LM7 4l80 swap question
Old Jul 25, 2016 | 09:49 AM
ek9beezler's Avatar
Default LM7 4l80 swap question
I've searched around and couldn't find this answer. I got the flex plate and spacer in and then when looking at the mounting holes vs. the holes on the block it looks like everything lines up except for one hole. There are 7 holes in the trans and only 6 in the block. Closer inspection looks like it could've been sealed and welded where that last hole should be. Is this normal or is this unique to my junkyard motor?
Old Jul 25, 2016 | 10:17 AM
squarles67's Avatar
Normal. The one on the passenger side of center is not tapped on a LS
Old Jul 25, 2016 | 10:35 AM
ek9beezler's Avatar
Thanks! Do most people tap it or leave it be?
Old Jul 25, 2016 | 11:33 AM
squarles67's Avatar
Leave it be.
It was removed for a reason, it hit something although I don't remember off the top of my head what that was.
Old Jul 25, 2016 | 11:54 AM
ek9beezler's Avatar
10-4. Thank you.
