L33 5.3l will 862 heads work?
The 862/706 are cheap with 61cc chambers. Usually found for $100-150 or less.
317's are a 6.0 head and the best cheap head available IMO. Usually found for $100-200 complete. They have the 71cc chambers and the larger intake valves and ports similar (but not quite as good) as the 243. They will drop your compression around a half point on a 5.3. (.6 I seem to remember). Much cheaper to do a home port job on a set of 317’s and have them milled to your desired CC size. I picked up my last set for $120. I believe a .040 is about the max suggested mill and nets about a 64cc chamber.
