head gasket difference
Old Aug 25, 2016 | 04:55 PM
Camaro350Z28's Avatar
Default head gasket difference
I tried searching. having issues finding the info i need.
through searching ive found the part# ending 8544 head gasket people say to buy. then i go to gm and they have a part# ending 9226 head gasket. im just curious if someone can enlighten me on the difference between the 2 so i can make my choice.
unless there is something other than those 2 stock options someone can recommend. i was just planning on the stock gasket through research.
thanks!
Old Aug 26, 2016 | 07:31 AM
SAPPER's Avatar
pay attention to the max bore sizes. Also going too big will lower compression ratio numbers.
Old Aug 27, 2016 | 10:47 AM
Thank you for that!
