Cam only or the whole 9-yards?
What kind of power can it make with a cam using stock 853 heads? Can I get away with leaving the stock oil pump? Only 72k, still has good pressure and I don't much feel like dropping the pan. Any recommendations on who to call, or would an off the shelf cam do just fine?
Also, the clutch was definitely a mistake. It has less than 3k miles on it, so getting rid of it is a tough pill to swallow. The thing revs like a truck.
Any recommendations on clutch set-up? The car is probably one of the heaviest 4th gens around, with 4 point frame connectors, full sound deadened interior, and amp rack with 2 amps, and a 10" sub with box. The true duals add weight as well. I figure a lightweight clutch set-up would make launching this pig real difficult. Obviously the car needs a diet, but I like my music.
Any recommendations on clutch set-up? The car is probably one of the heaviest 4th gens around, with 4 point frame connectors, full sound deadened interior, and amp rack with 2 amps, and a 10" sub with box. The true duals add weight as well. I figure a lightweight clutch set-up would make launching this pig real difficult. Obviously the car needs a diet, but I like my music.Clutch depends on budget. I ran a monster S3 for over a year, and it's not bad. Upped to a RPS which is really expensive but really worth it. Weighs 31 pounds IIRC. No issues launching. I've seen some really light clutches from mantic and Tilton that use the flex plate from an auto to get it started and weigh 19 pounds at only 7.5" diameter. I would say if you find something in the 28-35 pound range you'll be really happy. Smaller diameter will help too. A monster S3 with aluminum flywheel will put you at 37 pounds I think. There's also the LT1-S that can get light as well
If that's not a worst case scenario for launch you'll have to show me something worse. In your case, since you're already gearing and keeping stock tires you'll be way better off than I was with a lighter clutch.
Can't wait to drive this with 4.11's and a nine inch rear. I can be fearless!
BTW change the oil pump when the cam is being done. It has to come out anyway. Mine picked up 8psi all across the board with a stock LS6 oil pump. I have a solid 40psi at hot idle since my cam change.
Spin that 99 ls1 to 7000rpm. My first ls1 over 10 years ago now was a 99. It ended up 540 HP flywheel, 7200 rpm shifts... stock short motor. Sure, one might break. Mine never did in 70,000 miles of thrashing it over 2 cam swaps then heads/cam max effort bolt ons and tune etc.
I would like to see where that puts me, then get deeper when the bug hits. If I do everything at once, I'm gonna get bored.
Although, I have to say I'm rather impressed with this car, considering it's 17 years old. It pulled on a 392 Charger(unknown mods, at least exhaust) today. I know they're heavy, but seem like 440whp out of them stock isn't uncommon.
