ls1 bad timing
Old Sep 5, 2016 | 11:02 PM
Portcityls's Avatar
Default ls1 bad timing
I did a H/C swap on my 01 SS... Started fine but then it started losing power and sounded like the timing was off... So I tore it apart again retimed started it up again, sounded normal and drove strong for about 10min. Then it lost power and sounds out of time again. Tore it apart again and everything seems fine... Is it because of no tune yet? Mods: 243 heads, torquer v2,ported ls6 oil pump, ls2 timing chain,ls7 lifters, full bolt ons
Old Sep 6, 2016 | 12:36 AM
DietCoke's Avatar
it's not going to run well without a tune
Old Sep 6, 2016 | 01:30 PM
Aaron at SDPC's Avatar
Like mentioned above. A tune is definitely required.
Old Sep 6, 2016 | 01:33 PM
HCI2000SS's Avatar
Yes most likely because of no tune
Old Sep 6, 2016 | 01:49 PM
svede1212's Avatar
Props on getting it to run 10 minutes. When I did my first cam the only way I could keep it running was to keep revving it.
Old Sep 7, 2016 | 01:21 PM
spy2520's Avatar
ditto
