What are the Best Stock Heads?
Old Sep 7, 2016 | 09:38 PM
Stampede4ever's Avatar
Default What are the Best Stock Heads?
I don't see this question much, or really know the answer to it. But I'm thinking first the 243s, then the 317s, then Idk.
I'm working on a budget LQ4, just for reference.
Thanks.
Old Sep 7, 2016 | 10:08 PM
pozesd99''s Avatar
I would say ls3 heads or 243's if your looking for a cathedral port
Old Sep 8, 2016 | 03:27 AM
HCI2000SS's Avatar
It depends on your goal and the rest of your build
Old Sep 8, 2016 | 08:58 AM
Darth_V8r's Avatar
Moderator
Ls7 heads
Old Sep 8, 2016 | 12:44 PM
I have a LQ4 with a broken exhaust manifold bolt on one side, that someone tried drilling out, at the wrong angle, and the other head had a broken valve spring, that bent the push rod, and bent the valve. Not sure what the price is going to be to fix both of them. So, that sends me to this question, what will it take to make 425hp, and 425 tq to the ground, on a budget?
Thanks.
Old Sep 8, 2016 | 01:19 PM
94LS1B4C's Avatar
cam and heads bolt ons and tune, about $1500-3000k depending on what you need.
Old Sep 8, 2016 | 01:24 PM
SAPPER's Avatar
The bolt is easy to remove if you have access to a welder, even a cheapie wire fed. Weld a nut to the broken bolt, unscrew. I've done many. Oh only if the head is aluminum and not the early LQ4 iron head.
Stock valves are easy to come by. I just threw away two sets. Sorry. But if you want to make that hp, you will need to do a cam swap anyway, so new springs, pushrods, etc will come with your cam kit. i.e BTR, TSP, Tick, etc.
Old Sep 8, 2016 | 04:13 PM
No, you don't understand, the drill bit lead off, I will try to post a pic soon. I can buy a new valve for like $5.00 bucks, not a problem. But that exhaust bolt worries me.
I was thinking a LS6 intake, I thought the LS3 had rectangle intake ports?
I just rode in a 2008 Vette, with LT, and a tune only, holy ****, I'm hooked now.
Thanks.
Thanks.
Old Sep 8, 2016 | 04:21 PM
SAPPER's Avatar
If you were near me and the head was off, I'd have that bolt out in a minute or so. I've had to get out some really butchered up bolts. The worst are ones that have an easyout broke off in them. They are usually carbide or tungsten and a welder don't like those.
Old Sep 8, 2016 | 07:46 PM
The gold drill is the hole drilled at the wrong angle, and the black drill is in a stock drilled hole. Not only is it drilled at the wrong angle but it is also drilled offset as well. I'm hoping it can be repaired with a keensert.
Thanks.
Old Sep 9, 2016 | 07:26 AM
SAPPER's Avatar
Yep, that's a bad deal. How deep did it go? Into head material or just deep enough till someone realized they screwed up.
Old Sep 9, 2016 | 12:18 PM
MaroonMonsterLS1's Avatar
best is a very relative term. it all depends what you want to do. In my opinion i'd get a cheap set of 241's (or 862's cut for a larger intake valve) and port the **** out of em. This will be cheaper, much cheaper, than 243's and porting those and easily capable of making that 425 you're looking for.
if staying NA, there would be no harm in milling the chambers to help get more compression, so no loss from the 243's.
Best is a mix of money, simplicity, and performance for me. for others its just performance. My way= 241's ported. strictly performance: not 241's
Old Sep 10, 2016 | 05:32 PM
GoatPilot87's Avatar
I just recently ran into this on a Ram. I was still at Dodge when the new body style came out with the updated hemi and they sent out RRTS to replace manifold studs. I've done hundreds of them but work for a large used car retailer now so I do all that we have. Never had an issue using left handed snap on drill bits and extractors of mine but didn't have them with me that day. Tried stepping bit sizes for it to grab and one broke off. Long story short it cocked sideways and by the time I got it out I had forgotten they enlarged the ports so it was less aluminum in the head now. Hit a coolant jacket. Ended up taking the head off, they tigged the hole solid, resurfaced the manifold flange surface, and used the gasket as a template to redrill and tap the hole. The machine shop only charged $236 and that included new exh guides they found loose, full cleaning, and valves being cut and cleaned. If your just looking to get it running and not buy heads it's an easy repair for a good shop.
Old Sep 12, 2016 | 07:26 AM
Does anyone know the head bolt pattern dimensions? Im going to try to fix the head myself. See if your sheet metal vendor will bend up a fixture for me.
Thanks.
