799 head question
Old Sep 11, 2016 | 08:56 PM
Krishneel1's Avatar
Default 799 head question
I have a ls1 with 799 heads. What GM head gasket do I use. Please provide part numver. Thank you
Old Sep 11, 2016 | 09:14 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Out of curiosity, I did a simple Google search of your question, and found a link to a full breakdown of all LS heads, along with part numbers for gaskets on the first page of results. How lazy are you?
Old Sep 11, 2016 | 10:39 PM
Krishneel1's Avatar
whats the link because I never found it
Old Sep 12, 2016 | 09:55 AM
Aaron at SDPC's Avatar
If you are running 799 cylinder heads on an LS1 block the GM part number listed below should get you taken care of.
GM# 12498544
Old Sep 12, 2016 | 11:54 AM
1FastBrick's Avatar
Here are 2 threads I created awhile back. It is some of the most copied info on the net.
Most of it is gen 3 stuff but alot of it still carries over.
GM LS gaskets, seals, and other part numbers. http://www.performancetrucks.net/for...thread-428941/
GM head casting numbers and info http://www.performancetrucks.net/for...g-info-434396/
Old Sep 12, 2016 | 12:30 PM
usnfenix's Avatar
ahaha I see what your doing there...
Old Sep 13, 2016 | 06:58 AM
SAPPER's Avatar
Disregard the LS1 F car set. They are the old graphite junk.
