SSR radius..leave it?
My question is in regards to the SSR...short side radius. Is there anything to be gained by easing it down? Or is it better left alone?
After an evening of online searching, I'm having trouble finding a consensus. It seems there aren't very many posts or articles on the subject in real terms of "its been proven that....."
Anyone have anything on this subject?
And you will find a lot of differing opinions on what works and what doesn't. I have read on this site that you can ease it down, as you said in reference to the SSR, and it usually increases flow.
Here is a link to a similar discussion on this site. It has a lot of useful links on post #7:
https://ls1tech.com/forums/generatio...guys-come.html
Hope this helps.
I think I've read about every thread that might contain any glimmer of hope on the subject. It seems there isn't a clear cut, black and white answer. Only opinions.
Does anyone have clear cut facts?
Read as much as you can and make a decision based on the information you have available. When dealing with information presented on a forum, you have to either pick someone's opinion based on how they lay out their information, or you count opinions for/against what you want to do and choose the popular majority opinion.
You might be able to call and ask someone who professionally ports heads and get their opinion on what to do and what not to do, but most of they time they are very busy and are not very willing to freely give up the secrets of their craft.
I am in no way trying to discourage you from home porting your heads, but what is wrong with running stock ports with a nice valve job on shaved heads? Run them like that until you have enough money to get them CNC ported. Gotta love the port-to-port consistency of CNC porting.
I've been practicing on a spare 241 head.
I'm not exactly clear what constitutes "messing it up" or what would be considered beneficial.
The approach I've taken in practice is to start at the "peak" of the radius. Ive lowered the peak, then feathered the radius both towards the runner and towards bowl/seat. I have done this while staying off the straight and curved walls, maintaining the original width so to speak. I then took a long strip of sand paper, maybe 3/4 wide and pulled it back and forth along the radius to contour it.
I haven't gotten very agressive at all. At most I removed .030 from the "peak". Maybe just a tad more.
Does this sound like a reasonable approach? Any input and those who are experience would be greatly appreciated. This is my first go with LS heads.
Don't be afraid to widen the SSR either, but be careful not to make the corner radii too tight.
I think I'm going to have the machine shop to a base line flow on my 243's. When I go pick them up I'll take this 241 that I've worked along and get his opinion. The guys I'm using are one of the top sprint/late model builders in the country. They should have solid insight. After I do the 243's I'll get a follow up test. Since I'm not removing large amounts of material, an increase on the bench should equal success????
I think ill stick with areas that are easily matched port to port. Those areas being the rocker bolt hump, the ramp, valve guide boss, and bowl to valve seat blending.
Thanks to all who offered advice
I commend you for trying, though. I do not have the ***** to try hand porting a GM head. Ford heads, oh yeah, all day... there's no way to make them worse.
A few days ago I actually decided to start checking with a few of the major LS CNC head porters. None was willing to discount the milling or valve work thats already been done. So that's what has really steered me into a home port.
I'm sure I read a thread or two about someone who tested after taking out the rocker bolt hump only, and lost mid list CFM.
The swirl ramp is also a matter of debate.
What about a simple bowl/seat blend and guide boss reshape? Any danger or grey area here?
