Finally doing heads w/sns3 Now with results!
#41
Subbed. Very curious as to what this setup does and what your impressions are.
Do you go with the regular or mild lobes BTW?
I've been eyeballing the same cam for a while now. If you're happy with everything when it's all done I may just replicate it.
#42
#43
I have had the cam for a few years now actually and I loved it before, and I have the standard lobes. In theory it should just get even better now with the added compression, better heads and going speed density.
#44
NA 469/441(on nitrous timing, on full tune up made 15 more) I think it had more in it based on that curve, they didn't seem to rev it up there to high
150 shot 604/625
Before
Overall the car feels awesome! All drive ability issues I had with it previously are gone. It is faster to rev, easier to drive, and obviously sounds bad ***.
High lights of changes:
243 heads to TEA TFS 215s
Johnson lifters
Manton 11/32" pushrods
tsp dumps to y pipe and slp loud mouth 2
Speed Density Tune
#46
Great numbers! I agree with that curve on NA it could probably peak higher.. I can't tell, what RPM did they take it to? I almost went with an sns3 but ended up going smaller, I knew it would be a beast with a nice set of heads. Now hit the track before snow flies lol..
#47
#50
Yea 6000 is very low for that set up.. probably could have taken it to 7k the way it was still climbing at 6000.. I bet it could have went 475 easy the way it was climbing.. wow that's on a mustang dyno? Phew that's one hell of a set up.. very nice
#53
Solid numbers! It will be interesting to see what it makes pulling it to around 7000 RPM.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
#54
Thanks guys! The car is a completely different animal now, the last couple days I have been driving it like I stole it and could not be more happy with the car. Pulls nice a strong through the entire range, idle is amazing, it seems happier in the lower revs now, throttle response is definitely faster. The valvetrain is damn near silent, but I can hear the ls1 sewing machine noise again like when it was stock. For giggles I pulled the valve covers to check the wipe pattern one more time and it is on point. My only complaint is that I still want more! Calling in a little bit to see if I can get on the old dyno for a comparison.
