Best cam for a lq9?
Old Sep 23, 2016 | 08:14 AM
1000000to1's Avatar
Default Best cam for a lq9?
I have a lq9 that will be stock other than being bored .30. What's the best cam to run for a little extra jam but still being a good street truck?
Old Sep 23, 2016 | 08:18 AM
Aaron at SDPC's Avatar
Give us a little more detail on the build. Any other modifications planned for the truck? Stock torque converter? What kind of truck is it, and what will the primary use be?
Old Sep 23, 2016 | 09:12 AM
HCI2000SS's Avatar
Agreed! You need to be more specific
Old Sep 23, 2016 | 10:26 AM
A.R. Shale Targa's Avatar
SO; "a little extra jam" is not specific enough ???
Old Sep 23, 2016 | 10:30 AM
HCI2000SS's Avatar
Right, what was I thinking lol
Old Sep 23, 2016 | 06:57 PM
1000000to1's Avatar
It's 58 gmc, trans is a 4l80 has the factory fuel injection setup and headers. Otherwise a stock lq9. Not going to bother boring it because cylinders turned out to be good. Since I have the motor torn down I figured I'd swap the cam so what's a decent street cam for these?
Old Sep 23, 2016 | 09:25 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You have failed to provide TC stall speed, rear gear ratio, tire size, or intended usage. These are all CRITICAL to finding the right cam. With that info, many knowledgeable people here could give good input.
Old Sep 23, 2016 | 10:46 PM
99 2500's Avatar
I like the 1449041 crane cam, adds more power from idle to 6000 rpm and idles almost like stock.
Old Sep 24, 2016 | 04:38 PM
DavidBoren's Avatar
Call Martin Smallwood or Kip Fabre, or any of the other vendors on this site for that matter. They will ask you very specific questions and tailor a camshaft to your exact combination and desires.
You ask a million people and you get a million different answers. So, go straight to the source, have a conversation with a professional about what you have and what you want, and get a custom camshaft designed specifically for you. Sure, a custom grind on a Cam Motion core is probably more expensive than Grumpy Uncle's Stage 2 ultra lope cam, but buy once cry once.
Anything worth doing is worth doing right, so you might as well get the camshaft that is right for your exact setup and your exact ambitions.
Old Sep 25, 2016 | 10:33 AM
xdanny510x's Avatar
Since he wants extra jam then just throw the ms4 or ms3 in there lol
Old Sep 30, 2016 | 03:05 PM
mjs1012's Avatar
^^ this guy gets it. If it were me, id look at something with good low/mid range power with a converter to match.
