Ls2 408 motor build- compression
Cylinder Head Volume (cc) 59 Cylinder Head Vol (cubic in.) 3.599
Piston Head Volume (cc) 4 Piston Head Vol (cubic in.) 0.244
Gasket Thickness (in.) .051 Swept Volume (cubic in.) 51.086
Gasket Bore (in.) 4.060 T.D.C. Volume (cubic in.) 4.503
Cylinder Bore Diameter (in.) 4.0325 Gasket Volume (cubic in.) 0.660
Deck Clearance (in.)
Note: Neg. number above deck, Pos. number below deck 0 Deck Volume (cubic in.) 0.000
Stroke (in.) 4 Static Compression Ratio 12.345
OPTIONAL DATA
Rod Length (in.) 6.125 Adjusted Stroke (in.) 3.092
Intake Closing Point (degrees) ABDC @ 0.050 lift plus 15 degrees 66 Dynamic Effective Compression Ratio 9.770
Yes, certainly keep the quench as close to 0.040" as possible. Some people here advocate closer to 0.035".
With that said, a later IVC will still help.
You can get away with high static and dynamic compression with E-85; it does have a higher octane and it will certainly run cooler. Just don't go too crazy. And make sure your cooling system is up to the task, too. If it gets too hot - like above 200* or so - it will detonate badly.
You can get racing e-85, with 15% high octane racing fuel. But it's not cheap and it's not easy to come by.
As said above, a later IVC point will lower dynamic compression. But it will increase cylinder pressures at higher rpm's.
I'm going to be running Mahle regular ductile rings with gaps at .018 and .020. I think that would be alright on this motor running with e85.... thoughts?
