Main bearing clearance and type of oil
Just put together my 408 ls2 motor. 4 inch crank. 4.030 bore. NA
My main bearing clearances are attached below along with the bearing taper. The motor is an aluminum block so it will expand a little bit more.
What type of oil do you guys think I should run?
Rotella synthetic 10w-40?
(Yes, I know it's diesel)
