What pistons do I have?
Old Oct 11, 2016 | 04:22 PM
Ralls's Avatar
Default What pistons do I have?
I bought a stock ls1 long block a few years ago that had a broken piston ring land. So I bought a set of stock pistons that are supposedly ls6, but I'm not sure. They have a floating wrist pin and look stronger than the stock ls1 rods I removed. Both are flat tops. The diameter seems identical. I thought ls1 and ls6 rods/pistons were the same? Maybe a 2002 ls6?
Right is the stock ls1 I pulled out.
Old Oct 12, 2016 | 10:11 AM
JoeNova's Avatar
Restricted User
If the piston diameter is the same, run the stronger ones.
Old Oct 12, 2016 | 12:48 PM
1FastBrick's Avatar
If that bore is for the 5.7L, You have the later Second generation rods and pistons likely from a 2004 GTO or Corvette before the LS2 change over.
Old Oct 12, 2016 | 05:56 PM
Ralls's Avatar
Thanks. I just measured them with a micrometer and the bore is identical. I have only seen this design with 5.3 truck blocks so I wanted to clarify. I wonder how much stronger these are.
Old Oct 13, 2016 | 12:06 AM
1FastBrick's Avatar
A lot stronger!!! People are making upwards of 1000HP on them.
Old Oct 13, 2016 | 05:21 PM
Ralls's Avatar
Well good! That's what I was hoping to hear. I'm doing a "run it till it blows" mild turbo build so hopefully these will help. Thanks guys.
