Another Cam Question... Need help quickly please.
I want a cam for it that hits hard. As far as racing it and all I really do not care. It is just a cruize in truck to play with. Weighs 2800 and has a 3.73 gear and has an HP tune by Jay Turner.
I have three questions.
How big can I go without having to worry with push rod length issues
What cam do you recomend that will hit hard. Just want to ride into a cruize or car show with people saying damn.
Can I reuse the roller lifters in the motor now? I always thought you could but just checking.
Just get a comp mother thumpr and some cheap LS6 valve springs and set the parking lot on fire with your obnoxious loping weiner extension. Down the road you can spend the same amount of money all over again for a cam properly specified for your application that will actually perform and move that truck like a 6.0 is more than capable of doing.
I know everyone wants a cam that hits as hard as possible but I really don't understand why. I'm a drag racer and I'm running a little cam right now with less overlap than a GM hotcam (-5 @0.50) that idles almost stock and I embarrass those poorly set up donkey *@#% cammed cars all the time because I have a well sorted combination. They always ask if I sprayed NOS! and I tell them no, I just used some restraint and common sense when I selected my camshaft!
I hope you don't take my ranting personally but I'm really sick of this poser cam lope mentality in the lsx world. I realize that cars and engines are a learning experience and everyone is a unique snowflake that wants to express themself but i am so tired of over-cammed poor performing setups I could scream!
For me there is a tipping point between lope and brick in a dryer. Too much cam for your setup and it will sound like a brick in a dryer and anybody that has any idea about cam specs, engine building, racing, etc...will know that you have the wrong grind in your engine. That sounds less cool than a stock idle to me. If all you want to do is turn heads at a car show, spend 250 bucks on a bottle of nitrous and just a purge kit and spray at every show you drive to. It will have the same effect as a donkey **** cam. All show, no go.
Then theres the brick in a dryer https://www.youtube.com/watch?v=GUEz...ature=youtu.be
Sounds similar enough to be sad. You can have a car that sounds good and still runs well, but that means giving up a little lope.
Lingenfelter GT12 is one that comes to mind. 227/235 115. 1 degree of overlap.
Also, you'll probably want to replace those factory pushrods. Aftermarket cams have more extreme ramp rates on the lobe profile and typically more lift as well, so pushrods would definitely be something to replace. Same with valvesprings.
Much like heart surgery, A camshaft upgrade should be done right or not done at all. If you buy a cam for sound you will never be happy with it. You can have useable tourqe and horsepower for the same money and your tuner with thank you for not bringing him garbage.
I imagine a vendor will chime in at some point. They should want every detail about your setup you can provide so they can make an accurate recommendation.
This camshaft will also make great power too. So, it is win-win for you. The specs are 232/244 111+4. Typically I would make this camshaft with .621" lift and recommend a dual valve spring. But, I can also make it for you with .595" lift and you can use it with our PAC 1218 beehive performance replacement valve spring.
The camshaft grind number for use with our .650" lift dual spring is: XA232/365-XA244/355-11+4.
The camshaft grind number for using the PAC 1218 beehive style performance replacement spring is: XA232/350-XA244/345-11+4.
As for your stock pushrods, customers have reported bending them in performance use. It is just not worth it to take the chance for no more than they cost. So, get yourself some of our hardened chrome-moly 7.400" pushrods too.
