918 spring change
Old Jun 21, 2004 | 05:59 PM
zyal8r's Avatar
Default 918 spring change
How often should the comp 918 valve springs be changged with the TR 224 cam?
thanks in advance
Old Jun 21, 2004 | 07:19 PM
Ryan02SS's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/165867-c918-test-pressures-4800miles-tr224.html
I've since changed to the Patriot Gold Duals and couldn't be happier. I did not feel safe running the single 918's after finding out they had lost that much seat pressure after only 4800 miles. Running a dual spring that is probably the best on the market now has given me much better peace of mind.
