LQ4 Leak Down Help
Old Oct 18, 2016 | 08:52 PM
marks86's Avatar
Default LQ4 Leak Down Help
I found TDC#1 by lining up the timing marks on the timing chain, the problem is how do you move to the next cylinder to TDC to check it. Everyone says just put the piston at TDC on the next cylinder and perform the test. I'm confused on how to accomplish this.
Old Oct 18, 2016 | 09:29 PM
truckdoug's Avatar
1/4 (90*) rotation of the crank puts the next cylinder in the firing order at TDC
