Drivabilite with this cam
Old Oct 17, 2016 | 11:54 AM
moekluse's Avatar
Default Drivabilite with this cam
Had this new cam laying around. It's a 224/230 @50 .609 .604 115lsa. Doing a boosted forged 5.3 and I know this cam will make power but will I have drivability issues? I know it's on the large side, I have not yet decided on converter stall, as I need a new trans and rear-endetails to support motor. If anyone could also recommend a stall for a street car. Thanks
Old Oct 17, 2016 | 11:56 AM
Aaron at SDPC's Avatar
Drivability with a proper tune, and aftermarket torque converter won't be bad at all.
Old Oct 17, 2016 | 12:12 PM
moekluse's Avatar
happy to hear that, now I just need a converter, thanks
Old Oct 18, 2016 | 08:56 AM
kinglt-1's Avatar
call FTI for a converter...and yes that cam should drive ok and be fairly easy to tune even on a 5.3 being it has -3 degrees of overlap.
Old Oct 18, 2016 | 12:32 PM
Rise of the Phoenix's Avatar
All depends on the tune. That cam is by no means some donkey dick cam that's not going to behave itself, but with the wrong tuner, you'll think it's the T-Rex.
Old Oct 18, 2016 | 02:25 PM
moekluse's Avatar
Ill call them and ask for suggestions. Thanks
Old Oct 18, 2016 | 05:17 PM
99 Black Bird T/A's Avatar
I think that cam should drive pretty decent with a good tune.
Old Oct 18, 2016 | 10:54 PM
JakeFusion's Avatar
Super Hulk Smash
It'll drive fine. Hell you could leave everything stock and just tune the VE table and spark tables and it'd run fine.
