need help on cam swap
thanks dayton.
What are your goals for the truck?
Hot Rod Magazine did a test with a 5.3 and several off the shelf GM cams. I would read it first then move from there. There are also some good threads about using GM cams in a 4.8 if you Google it.
Link to Hot Rod Article----> Link
What does that mean to you? do you want to start dragging corvettes from stoplight to stoplight? Do you want to out-tow a duramax? Are you just wanting to sound cool and do burnouts? What do you realistically want to achieve with this truck?
If you go with a cam that size, you will be needing springs, pushrods and probably lifters.
If you are dead stuck on that donkey d**k cam, I'd go with arp rod bolts and spin the thing to the moon...because that's the only area it will make power. 4k stall, really tall gears (4.10 probably), and LOTS more compression. I'd mill the head and run a thin gasket to get lots of compression. Go right on the edge of PTV clearance issues. Also, install it on a very early intake center just to try to salvage any amount of torque that you can.
Simply put this is a very poor cam choice for this engine, and I would change cam choice before i'd change the other things listed.
The fact that its on a 115 LSA means that it still has negative overlap, so the compression increase isn't as necessary. The main problem here is that its focused on 4000-7000 RPM power, so in a car it would be a great cam, in a truck, not a great cam. 90% of the people here don't seem to understand that the exact same setup in a car and in a truck need different cams.
Big Duration sells cams because of the bigger is better mentality. It's a proven fact. Then the cam designer has to do a bunch of BS to try and fix it. Widen the LSA beyond reasonable amounts or advance it a ton to get low end back...which throws off the valve events leading to a downward spiral **** show of a camshaft overall.
This one would sound mean, idle decent, and make vacuum. 216/222 @ 111.
https://www.summitracing.com/parts/c...make/chevrolet
A 215/215 109 LSA in a 4.8 would give good gains across the board, especially for a truck, with a good sounding idle, but you'll start to kill the rev-happy nature of the 4.8.
I've used this one twice in trucks, and it provided decent gains across the board, mostly in the mid range.
https://www.summitracing.com/parts/h...make/chevrolet
I'm pretty confident A 215/215 109 LSA would carry the power out at least as far as the OEM intake is good for.
On as side note the 220/220 @ 111 .525 lift cam worked great on my 4.8. Was snappy down low (with a 3200ish stall anyway) and pulled past 6800. I"m sure the cam in the video I posted above would be even better.
Good comparison where they had 3 test cams and varied the LSA only.
http://www.superchevy.com/how-to/eng...formance-test/
If changing nothing other than cam, I'd shoot for something like a 212/215 109+4 with around .550 lift. Should keep torque where you want it and carry decently up to the rpm i suspect you'll actually turn. The cams listed above would also do the trick really well
, this is just my .02 for a spec.Best of luck picking one out, let us know what you decide and how it ends up working for you!
