The best low and mid lift porting or valve work?
Secured a set of 243s. Cam is .578" lift so really do not need flow nos. and the required porting beyond cam lift peak.
Looking at mid and low lift nos.
what mods work best on a 243 to increase the low and mid nos. A valve job? What type? I read a poster 243s pickup quite a bit just with a good valve job.
Same for 241s by the way.
Intake Valve Seat Angle
OK, you gave me a great idea, change the intake seat angle to 30* as is on the Ford FE engines for NASCAR Racing.
I have a cut head, one cylinder 823, for back/back testing on my flow bench.
My choice for low lift flow increase is for the WIDE lobe center cam use that I like to fit that ALSO allows for higher static compression and flat top pistons.
What diameter of Intake Valve should I test ?
Lance
Lance
Back in the sixties Buick, Olds, Pontiacs had the 30 degree seats to maximize the area for Flow when .400"-.430" lift cams were prevalent. Drag racers with .900"-1.00 valve lifts have been using 50-55 degree seats for years since nothing under .500" even matters to them
The OP would be best suited to send the heads to AI for a valve job and perhaps a CNC chamber program to pick up 20 or so cfm and maintain a small high velocity intake runner
Lance
Lance
I'd suggest the standard 2" cathedral port intake valve, since low lift flow likely means more to that crowd.
