lifter question
Old Oct 31, 2016 | 10:15 AM
tom70's Avatar
Default lifter question
looking at buying a camshaft for a lq4 seller said cam is solid roller. my question is can I use hydraulic lifters?
Old Oct 31, 2016 | 10:29 AM
JoeNova's Avatar
Restricted User
Why honestly go through the trouble of getting a cam that is probably wrong to begin with, and then purposely use it wrong?
Old Oct 31, 2016 | 10:35 AM
farmington's Avatar
never never never use hydraulic lifters on a solid cam or vice versa.
Old Oct 31, 2016 | 10:49 AM
Aaron at SDPC's Avatar
Like others mentioned. In the long run you will be much better off purchasing something specifically for your application.
Old Oct 31, 2016 | 11:03 AM
tom70's Avatar
specs are what I wanted other than duration. duration was high. but was going in a drag engine. I'll just buy proper cam. thanks for info.
Old Oct 31, 2016 | 11:05 AM
tom70's Avatar
here are cam specs Duration @ .050" of 251/255 with .348"/.348" lobe lift and it is on a 107 lobe separation angle.
Old Oct 31, 2016 | 11:38 AM
JoeNova's Avatar
Restricted User
Duration means nothing in this circumstance, lobe profiles are typically very different between solid and hydraulic.
