SBE LQ4 NA Need Top End Advice
Hoping to get my son's car (98 in sig) to high tens on motor (and the juice is for me).
Just interested in some more cathedral port combo's for the low compression LQ4.....
Again, OP and I are both interested in a max effort for track only.
Thanks,
Lsxrt fast 102. Let AI work the 317. Hardened pushrods. Ls7 lifters ,or full roller, the lightest valves you can afford maybe even step up to ls9 valves if they work them in the 317 . Get them milled as far as you can. Gonna need a cam specd to your heads.
i have purchased a set of 823s from a member here. Now looking for what piston to go with. Engine shop say lets make the bore 4.030, since ill be buying pistons is there a shelf piston that can bring me up to around 11:1 compression or should i just mill the heads with a flattop piston?
