My TSP 396 Stroker missing HP
You saw the car at the last RSD. It was the black WS6 Convert.
Anyhow, the 4400 lbs is a pretty close
3800 car
200 lbs driver (Yeah I can go on a diet)
120 lbs cage (steel)
65 lbs increase for the iron block
20 lbs increase in Torque arm
90 lbs gas (15 x 6 lbs per gallon)
Alright 4300 lbs
As far as your missing power, change those Comp 'R' rockers out for stock rockers and see if you don't pick up some of that missing power. Those Mac Mid-Length headers probably aren't helping you too much either, especially because you're flowing a lot more air with this 395 CI Motor.
I'll bet that if you change out the rockers and put a nice set of longtube headers on you'll get almost all if not all of your power back.
Good luck and let us know how it turns out.
Sometimes dynos lie.
A buddy of mine has a heads/cam car. He's strapped it down several times, on different dynos. Consistently 400 +/- 5 horsepower.
He traps 122-124 mph. Nearly full weight (removed passenger & rear seat, swaybar, spare tire, and has skinnies/slicks - that's it for weight reduction). Has working A/C and everything.
I put down almost 460 rwhp. I weigh less. I trap about 125. Hmm.
Makes you wonder about yon dyno racing, eh?
As for a convertible weight, my 94Z weighed 3800 with me in it (~170). But that's bone stock with no extra 'stuff'. Take a little out for the LS1 vs LT1 difference, but add in all the extra stuff... I could see 4200 lbs... 4400 is stretching it tho, IMO. Still, much like my buddy's car, "something's weird".
Most guys that swich from MACs to LT's gain MAYBE 4-5 RWHP peak up top and a bit of torque down low.
Mac headers aren't all that bad folks, some really fast cars run them, albeit with an aftermarket ORY. Mids have been proven to beat LTs in several magazines, confounding even the editors of the mags.
Let's see the dyno sheet.
Tune on a dyno. Race on a track.
Thanks guys
As for rocker arm stud flex, we're not talking about solid roller springs here. These springs are really not that stiff in the realm of things.
Thanks guys.
Ok, an iron block is 100 extra pounds and let's say you weigh in at 250 lbs, I still don't know where the last 400 lbs in your car is coming from.
