Does my measured pushrod length check out?
Basics are 243 heads - no milling, TSP Torquer V2, stock rockers, .040" head gaskets, LS7 lifters.
I have the comp cams push rod checker and am following vettenuts' process here: http://www.corvetteforum.com/forums/...ow-to-use.html
When the length checker is at 7.200 (8 turns) I have a little vertical play.
I turn the checker another half to 8.5 (I have to remove it every time, I can't get my fingers in there) to 7.225 and there is no longer a "click" when I pull up and down, but it does allow side to side movement.
Assuming a .080-ish preload for LS7 lifters, I should be looking for 7.305 push rods. This seems too short. I thought TSP used a smaller base circle and I would need longer push rods, even if the cup on LS7 lifters are .050" taller.
Any idea what I could be doing wrong? or is this a reasonable length for the setup. I was really expecting something along the lines of 7.350.
Thanks for looking. I was going to give TSP a call in the morning to see what they recommend.
Also check int and exhaust from at least one piston on each side of the motor.
But that sounds too short.
I get 10.5 quarter turns - 2.625 turns - about .1233" preload. I counted out the length checker 12 turns, so it should be 7.400" (stock length) and it's very close in length to the stock pushrod. I'm much more comfortable going with a 7.350 pushrod. I gotta find a set of calipers big enough to measure and check them both.
I measured the pushrod I used to check preload and measured in at 7.397. So it makes sense if I went with a 7.350 pushrod, my preload would be .0733" which is in range for what I've seen for recommended preload - moreso then .1233".
