Building a 700+ HP LS6 and need some input
Old Nov 14, 2016 | 09:51 PM
Probandit's Avatar
Default Building a 700+ HP LS6 and need some input
I purchased and LS6 out of a 2004 z06 corvette. It has 85k miles and I am swapping it into a pro touring 78 Trans am. I have read more posts and articles than I care to count on how to make my HP goal.
The question is:
I don't plan to add forced induction right away so, What should be done to the engine in preparation for turbo/supercharger that won't need to be revisited again?
Old Nov 14, 2016 | 11:32 PM
A.R. Shale Targa's Avatar
Drive it to 200,000 Miles where the ring end gaps will become loose enough to turbo it with 8-10 pounds on E85. Done. 700
Old Nov 15, 2016 | 10:43 AM
conan's Avatar
Run the motor as is until you go forced induction. Then decide what form of forced induction you are going to go with and build from there.
Old Nov 15, 2016 | 06:47 PM
imma_stocker's Avatar
With the limited info provided...... be sure the crank can rotate 360* then regular oil changes.
Old Nov 15, 2016 | 11:20 PM
Probandit's Avatar
Thanks for the replies. Guess I'll keep doing my research, figure it out and let you know how I did it, or not!
Old Nov 15, 2016 | 11:22 PM
Probandit's Avatar
Thanks Conan for the reply.
Old Nov 16, 2016 | 08:19 AM
conan's Avatar
Do you have an Idea on what type of forced induction you want to go with ? Turbo, centrifugal supercharger, roots style blower ??? If you were dead set on what road your taking the advice would better. Sure you can turbo/supercharge any engine but the set up could be far from optimal, and there is a difference between a turbo motor and a blower motor.
Old Nov 17, 2016 | 08:08 PM
99 Black Bird T/A's Avatar
With the long term goals you've mentioned, I would want to put in a fresh set of stock LS6 factory valve springs in and check the rockers as preventive maintenance. New spark plugs and wires too because they are almost due. Check the throttle body and may be clean it. Change the oil. Check the PVC system. Then i would enjoy the motor for a while.
I wouldn't start modding until you decide what direction to you forced induction wise.
