At what point is a forged crank necessary?
Whats going on guys, I did some searching and couldnt find anything that directly answered this question. As it states in the title, at what point/power level is a forged crank absolutely necessary?
I never really considered this question until talking with a good friend about my current engine build. Just for some background, my build is a LM7 5.3 going for boost (either a big single or twins) with the following plans for the bottom end:
TSP 347 rotating assembly (3.903" wiseco dished pistons, TSP H-beam rods w/ARP2000 bolts, factory GM crank)- not yet purchased
ARP head and main studs- already purchased
So in telling my friend about my plans for the rotating assembly, he goes on a rant about why I need to get a forged crank instead of a factory one. His argument is based off of a few people he knows who have managed to break factory cranks under moderate power levels (500-700rwhp). From what I know, those guys were running procharged setups on true LS2s. The only sense I can make of those instances are that perhaps the added stress from driving the procharger snapped the crank, or their bottom ends were never properly balanced. But, I do not know enough about their setups to draw any conclusions.
Now from my research, on here and other sites, I've always seen guys making serious power with a factory crank on a turbo 5.3 setup. My goal is to build a bullet proof engine that can safely and reliably run at 700~800rwhp. So for my build and goals, would a forged crank be worth the money? I'm fairly confident I can reach my goals with a stock crank, but would like to be sure before I pull the trigger on a rotating assembly.
Restricted User
700-800whp is still within range of the stock internals.
The stock crank gets iffy around 1400 hp, which is about the same area that the 4-bolt OEM blocks stuggle to keep the heads sealed.
Stock block? Stock crank.
For what your goals are I would recommend sticking with a stock crankshaft.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic302845_6.gif)
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Given your choice of boost (eg. turbos) and desired power levels you will be fine with a nice Gen IV crank especially if you keep the RPMs relatively low.
Although depending on how much you have to pay for a stock crank you may be able to find a slightly used forged crank and only have to pay an extra couple hundred more which is not bad. But I wouldn't go out of my way to spend $800+ for a forged crank on that build.
OK, I realize the "HP" question being answered correctly.
My concern does relate, the "cost" question.
At this time I have Forged 4340 crankshafts on sale, 4.10" & 4.125".
These will be at a great price, just PM.
These are forged/manufactured in the Calles, Scat, etc. plant, the same as their "intro" class, NOT BILLET.
This crankshaft has 1850 BW, good for metal removal when balanced. ( No Mallory)
Thus if the OEM crankshaft needs a "grind", a balance with "heavy metal" AND RE-NITRATED, COST is LESS for a new crank.
What do your rods weigh ?
Lance
Lance
Thank you everyone for the feedback, I'll be sticking with the stock crank like originally planned.
Lance,
I appreciate the offer. Since the crank I have only needs to be polished and balanced I'll be sticking with that. It also helps that a good friend of the family is an engine builder, so costs will be minimal.
Lance,
